Antec P180 and PCI card fitting problems
Arcenite
Hello,
I just got myself a Soundblaster X-FI Xtreme Music and it will not fit. I mean the card fits into the slot, but the case is preventing the metal bracket from entering into the bottom of the case (near the motherboard) all the way. It looks like it should fit, and the only difference between the bottom of the metal bracket on the card and the bottom of the spacers (the things in the case that you take out before you install the card) is that the bracket on the card is a little thicker. I don't know if this is a common problem or not, I had a similar problem with another card but I just cut about an inch off of the bottom of the bracket and it fit fine. I really don't want to mangle my brand new sound card.
Thanks!
Bill :cool:
Arcenite said:
Hello,
Thanks!
Bill :cool:
I had that problem with another antec case and my PVR 250s. I filed the end of the bracket a bit and then it fit.
I had the same problem but managed to get all my pci cards to fit by taking off the other side panel and using some force.
I had this problem installing my PVR-150 in my P180. I had to yank the bracket off the card, and bend it until it fit, then I put it back on the card and it went in. Took me almost half an hour to get that thing in. :rolleyes:
