Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have one, I like it. Only problem I have is that it is about 1inch too deep, so it sticks out from my tv holder than I want it to. Besides that its cool, needs a different color HD LED too, mine is orange
edit: it doesnt get hot, i only use it for HT stuff so maybe thats why but if you think you might have heat issues buy one of those PCI slot blower fans
I just got mine delievered yesterday You souldn't have heat issues unless your OCing, but if you do, i'm sure you can rig something up to make it cool better. The case is nice though, i'm pretty pleased with it, especailly considering you get a TruePower 380W Power Supply with it. In my mind, it was a cheap alternative to the other HTPC cases which ranch up to $200 w/o a power supply. I wasn't ready to put that much money into my HTPC quite yet, but the Overture definately does the job
