Antec NSK3480, extra fan/foam question.
colinstu
Browsing around [H], user: krick had the exact same idea for cable management. The only difference for me is that I'd also put in some sound dampening foam.
Here you can kind of see where I'm going to be putting foam in. The question is however, should I put in a front 92mm fan? And if so, should I put it on the top or bottom?
I think the CPU and back side of the case should be cool enough, and that CPU fan should also be sucking some of the heat off the ram. If I put a fan on the bottom to assist the video card, the fan would still be in a crummy spot. But I'll be using DFI's mini-P45 board, so maybe the video card won't be as bad. Video card being an evga GTS 250.
Also, where is a good place to get that thin "mat" type foam, and where can I also get that thicker foam, but with the wavey side?
Thanks all
