Hello,
I am looking for a case to be used in a possible HTPC build.
The build will be very simple. mATX board+CPU+RAM, DVD-drive, HDD, no extension cards planned so far, with the exception of something that enables me to use composite out (no HDTV yet)
I narrowed it down to the two Antec cases NSK2480 and NSK1480, since these are pretty much the only ones that come with a decent design, good PSU and budget-friendly price.
Pro 1480:
- smaller, not as boxy, would fit better into the furniture
Pro 2480
- 120mm fans (possibly quieter)
- full-height PCIe cards possible (not sure if needed)
- 380w earthwatts PSU same quality as 350w version in the 1480?
I would appreciate any input on this, maybe someone was lucky enough to test them both?
Thanks in advance,
Tim
Pro 1480:
Pro 2480
Thanks in advance,
Tim
