Tuthmose
- Nov 4, 2009
Has anybody gotten their mitts on an Antec Nineteen Hundred? Looking at it, it appears that one could drill out a couple of rivets and pull those drive cages out of the lower section, making room for a pair of 480 rads (running front to back, parallel to one another).
The rub would be how high that section is. Is there enough room between the bottom and the divider/floor for the rads to fit? Are the door openings (which, because of upwards protrusion of the reinforcing lower rail, appear smaller than the inner chamber itself) big enough to allow 120mm fans to stick out if a push-pull configuration was fat enough to warrant it? If anybody has access to one, Id love to know what the measurements of that section are. . .
-Tuthmose
-Tuthmose
