Hi there all. I built my new system in a nine-hundred two case on the weekend and installed my Zalman 1000w HP power supply.. the only thing is that the PSU fan sits at the botttom of the case and there seems to be very little to no space between the case and PSU for the 120mm PSU fan to do it's work.
Have I installed this incorrectly.. i.e. should I install my PSU upside down so the fan points up ? Or alternatively, should I simply drill a nice little hole in the bottom of the case so the air can be drawn up through the base ? Or do I not need to worry at all ? It's been humming along for a couple of days without any real issue.. the PSU fan isn't ramping up indicating overheating/stress etc.
Cheers
1000
Cheers
1000
