@ CompUSA, $30 instant off, $30 rebate:
http://www.compusa.com/products/pro...ode=342484&cm_ite=CompUSA+Logo&cm_cat=1066642
i dont know why but i think these cases look gawdy
That's when I got mine too...man that was a great deal.I got mine for $60AR back in April. This one isn't quite as hot, but still an awesome deal!
my concern is the PSU being at the bottom but my enermax has 2 fans so its got good cooling, just concerned about overall temps etc...
I'm not sure what you mean... are you concerned this case will have higher overall temps because the PSU is on the bottom?
My enermax is the same way. You've got one fan pulling air into the power supply and one fan blowing out of the case. But wouldn't that configuration mean that all of the heat generated by the power supply would get vented out? Especially since there are 3 other really nice size fans?
I got in on the Fry's deal, but I got BB to pricematch Fry's.
BTW the fans LED fans are 120mm not 90mm.
