Antec NeoPower 650 Blue?
rayz
I'm looking for a relatively quiet and reliable modular PSU.
This is what I'm running now
Giga P35-DS3R mobo
E6750 2.66 ghz - soon to be OC'd
2x2gb G.Skill Ram
1 HD
1 9800 GT - will be upgraded in time
1 HT Claro+ Sound Card
3-4 fans
may go SLI with future build
I'm assuming a solid 600-700w PSU should be sufficient and safe, right?
The NeoPower is $100 at the egg right now, would like to stay under $150. Was also looking at the Corsair HX620
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371010
I encourage other suggestions and appreciate your feedback!
Absolutely. I'm running a nearly identical setup, but with 4 ram dimms, an overclocked E8400, and six fans including a 200MM on the exact power supply you're looking at.
zomg thanks for the link that will be my next psu if it has lifetime warranty.. been waiting for bfg modular psu's for a long long long long long time.. (thats all i use is modular ya im picky)
It has a five-year warranty. Only the ES-800 has lifetime.
That antec 650 is engineered really well. I like it.
two rails for cards and the other rail for hdd, etc.
