Antec NeoHE Question
jonathonball
I just bought an Antec NeoHE 500 and it works great.
But whenever I shut down my computer it takes me three or four attempts to get it started. It'll usually fire back up after I flip the power switch in the back a few times.
It doesn't seem to be getting any worse, but it is a pain in the arse. Any ideas?
A basic system with a build in graphics card might not draw enough power to meet the minimum requirements of the Power Supply. But you have a 6800 graphics card, so that might not be the problem. I'm also interested in the NEO HE power supply.
Shorts can cause that, its alot of work but you should try to remove the motherboard and float it on a non-conductive surface and see if it still does it. Of course, it could also be a bad psu, that cant take the rush current of powering up.
I can say right now that if your PSU doesn't have a problem, then it will power your system fine.
