I have one of the original Antec Neo 480W modular power supplies. Its been running my ASUS A8N-SLI board with a 3800 X2 and a single nVidia 7800GT for over a year reliably. Two weeks ago in the space of two days I installed Windows Vista Business and a BFG 8800 GTS video card. Vista installed just fine but when I installed the 8800 the next day the system wouldnt boot. No fans, no beeps, nothing. The only sign there was power was the LED on the motherboard. After removing the 8800 and putting the 7800back in the system still wouldnt boot. I checked the power supply, the processor, the memory and everything seemed to be OK. I was sure the motherboard was bad but then I said I should try it with another power supply and it worked. I swapped power supplies and the system is working fine. Strangely enough the Antec Neo is working just fine with the same 8800 in my Intel D975XBX with a Core Duo 6600.
Despite that I purchased a new Thermaltake Toughpower 700W power supply for the 8800 system and pulled the Antec out. Ive seen on this forum that there are problems running the Antec Neo with ASUS boards but my question is whether or not the Neo power supply is somehow failing slowly or if its safe to use it in another system. I mean it was running the ASUS board just fine and now it wont do anything in that system. That tells me something has changed. Id rather not have to ship the Neo back to Antec but now Im wary that something internal like the capacitors are breaking down and Ill be stuck with a doorstop if I keep it. Any ideas or suggestions?
