Antec Mini P180 Rear Fan doesn't work?
rickyz
As the title says... the rear fan for some reason does not like to work. I checked all the connections and they were fine... any ideas why?
After I checked my connections, I turned it on to test it and it spun but only til windows booted up. It stopped shortly afterward and hasn't budged since.
Any help would be greatly appreciated.
I read on newegg that a batch of the cases went out with a bad fan in them. They were supposed to ship an extra one with them.
Just replace it and go on.
I would test it with another fan but the mini is extremely cluttered. My temps are pretty good (36-38C) so it's not a huge issue. Also, I put in a DVD and the fan started spinning for 10 seconds then stopped. It seems like the fan works but only spins when it wants to. Maybe a powersaver mode?
the fans just faulty.. you can buy another one for dirt cheap.. or just email antec.. they will most likely replace it..
