A small mod here, nothing like my water cooling, or high end cooling mods...
Well heres the deal... i got a laptop from work($100) as they were buying all new ones... its older, p4, 2.8, 60 gig HD, 512 ram, it also came with a free wireless card and bag. Its a generic brand, So all in all, i cant complain. I just wanted it for the TV room for email, surfing, etc...some streaming, XM radio, etc....nothing heavy duty...
What i did notice was, it gets HOT on the bottom, when i do anything for any length of time...surf, stream, watch ah.... videos, yeah, videos.......in fact, it gets choppy from the heat after about 2-3 minutes of watching anything video related.,.. so i thought, shoot.. ill get one of those coolers....didn't want to spend too much, but i got one at Circuit City, that was $9 after rebate....if it doesn't work, well, it was only $9.
So I bought this cooler:
The only real temp i can monitor is the HD....at least thats all that Speed fan found to read... pre Cooler, it was around 50, and 55C under load... with the cooler, it was around 48, and 52.. so it was a little cooler, noticably. Also, i was able to stream about 4 minutes, before the stutters started to happen..... so not bad...and i left it for a while, but then i thought, i could make it better....shoot if i ruin it, it was only $9
Ill also tell you what. Its not the best design. It stead of blowing cool air up, and cooling the hot spots, it vents the hot air away, out the vents. Not that great, as there is no active cooling.
So heres what I wanted to do.
1. It has the annoying very bright BLUE led when its on. You could read by it. That needs to come out.
2. Add 2 mirco fans to actively cool the hottest part of the bottom of the laptop.
3. Mod the openings so the fans can blow out.
