Antec Lanboy (NOT Super) Air circulation
Mojo
I have heard from a few people that this case has heating problems. Is it much hotter than the Antec Super Lanboy?
I have the SLK3700AMB which is similar in design and the cooling really isn't that great.
= :D
I have one, the cooling is ok. All it has is a fan place in the front and in the back, other than those mount points, there is no other "vents" or slots or anything, it could be better. But I have no fans, and have yet to see any problems.
It's doesn't have the best airflow out there... but it certainly won't be a problem. And it probably is notably warmer than the Super LANBoy, but it's upside is that it isn't UNGODLY FUCKING UGLY.
We reviewed one back awhile ago when (WE) (OCA) was a site, and the probs was that if you have the HD in the lower mount and a big Vid card, 5900 for example they almost touch and there is no where for the heat to rise to.
Its blocked between the two and for the most part the circulation is poor......
How about the Coolermaster Centurion. Is that any better.
my lanboy keep my cpu at 56load no matter what cpu used and 32mobo. went back to my cheiftech clone and tempos droped alot 24cmobo and 43 idle
