daveyboy2006
- Jul 18, 2013
Hi, im having a small issue with chill control with my kuhler 920 watercooling.....
I have setup the profiles etc to how I want them to act at what temps of the liquid.
to start with, whatever profile I use (extreme,silent or custom) sometimes the fans get turned down to around 500rpm without me doing anything, and they get stuck there until I choose another profile or click another and go back to the one I was on.....
This is bad, because no matter what the temps are, the fans stay at 500rpm! or so, so if I have a game or something on, then my cpu temp goes way up and the fans wont go up with the liquid /cpu temp!
the fans work fine to start with, and go up with temps as they should, so they CAN be controlled upto full speed, so its not a bios thingy not letting it control the fans or anything like that....
Good job I had noticed this happening because the fans go quiet and spin so slowly its noticeable.
I assume its a problem with the antec chill control software? ive tried re-installing the prob, but its still the same.
everything is plugged in fine etc to do with the cooling setup, so I don't know whats causing it.
Anyone have any experience with this or know a solution?
