Antec Kuhler 620 questions
LordCalin
I bought 2 of them back in April... one is mounted on a 775 motherboard, the other on an 1155.
Starting last week, both are making a lot of noise
The first one is making loud really fast clicking noise, like something is caught in a fan.. but i've opened the system and nothing is caught anywhere.
The second one is making a loud pulsing grinding noise, like a rock tumbler or refrigerator..
any suggestions of what I can do or ways to repair?
Sounds like a pump issue. Normally I would say drain the loop remove the pump and clean it out, however as this is a closed OEM loop your options are rather limited. Seems like it would be time to contact Antec and peruse warranty repair / replacement.
^+1. The only noises I'd expect would be from the fan or the pump, and fan issues are usually quite obvious.
I installed an Asetek 510LC (OEM Antec Kuhler) and it had to let some bubbles run through before it finally ran silent.
