Antec ISK600
Zap
This was first mentioned in the SFF cases @ Computex 2013 thread. I just noticed the product listing at Antec's site.
I don't know how much it will cost. It is a YACC (yet another cube case). Can fit multiple drives, ATX PSUs, any graphics card and maybe even tower coolers. Think of it as a Cooler Master Elite 120/130, but with the PSU up front and not covering the CPU.
An interesting side note is one of the pics shows off the new Antec AIO liquid coolers, which seems to integrate the pump into the fan, using the same motor. Good thing is that the CPU block is really small (mod for graphics card use?). Bad thing is that you can't roll your own fan.
Dimensions as per their website:
- 195mm (H) x 260mm (B) x 369mm (T)
- 20.9“ (H) x 10.2" (B) x 14.5" (T)
So that's quite a bit bigger.
18L!? (if my 3 beers math is correct)
Why not just get a Node then? Better looking and although the AIO fan drive intrigues me, I'm scared of the limitations it presents...
195mm does not equal 20.9 inches. 195mm x .0393 = 7.6635 inches. So something wrong there.
This looks like a more subtle CM Elite 1XX. I definitely approve of the classier styling.
I am wondering is it a silent enough case for HTPC if passive video and 2x120mm fans. Case fan and PSU fan
