Antec Fusion for gaming?
Hi guys,
I've been planning this build for some time now, but after the usual re-reading before actually putting my credit card down, I'm having some doubts.
The plan was to make a small form factor PC and then use it as a HTPC a few years down the line. Hence the Antec Fusion v2 (which is purdy). Current build looks like this:
Inno3D 8800 GTS 640mb
Intec E6750
GA-G33M-DS2R
Corsair XMS2-6400 (2 x 1GB)
Sony DVD
250GB samsung HDD (scavenged)
Now, is this going to yield good gaming performance in the short-term (2 years or so)? I'll be gaming at 1680x1050 and hoping to play some Bioshock, after 4 years of only having a laptop with integrated graphics. Also, will the 430w PSU that comes with the Fusion yield acceptable performance?
Thanks,
flamearrows.
I don't think cases have much effect on gaming experience. The PSU should be fine with no overclock on the CPU.
Don't use the PSU that comes with the case, get a good Corsair, Seasonic, Silverstone,Enermax, or any other trusted brand of PSU. You're buying a nice case, a nice cPU, a nice mobo, nice video card, and nice RAM, why skimp on the power supply? Get a nice power supply too...
As suggested by rhansen, wait for the 8800GT to come out. It's going to single slot, which can make a huge difference in cooling and airflow in an mATX setup.
I have a similar build in the NSK2400. Im running:
e6400 @3.2 with fanless mini ninja
Gigabyte G33 DS2R
2GB Geil DDR2 800
8800GTS 640MB
Corsair 520w PSU
2x250GB Seagate 7200.10 in RAID 0
For cooling I have a 70mm Sunnon@7v intaking from the back and 2x120 Yate Loons@7v exhausting. Temps on the CPU run in the low 50s after hours of orthos and the video card hits low 80s. Temps are acceptable but could be better. Ive tried adding a fan to the mini ninja but I think it hurt airflow more then anything.
Its my HTPC, girlfriends gaming pc, and performs great @1680x1050. Your system looks great and should work wonders for some time.
The only suggestion I would make is to wait and see what the 8800GT does, hopefully we know everything in the next two weeks. Aftermarket cooling for the 8800GTS is to big to fit in the case and the stock cooler is very loud. Even if the performance is close on the 8800GT and 8800gts, the 8800GT SHOULD have some advantages.
The 8800GT should produce less heat(the GTS added a ton of heat to my small case), maybe a quieter stock cooler, or even some other aftermarket cooling options. Current comments on the 8800GT(nothing proven for certain yet) has it out performing the GTS so it should be a win-win situation.
hello all,
i'm planning to build a similar config for gaming with antec fusion, 8800GT and a Gigabyte G33 DS2R, so maybe you can help me. It's been a loooong time i haven't built a serious config so i'm kind of newbie in some parts :rolleyes:
I saw that Gigabyte G33 DS2R has only 2 molex fans connectors, 8800GT has one fan, processor has another one and antec fusion case has 2 fans.
I need then 4 molex connectors fans and i suppose you are in the same case.
How did you deal with that ?
hello all,
1. Stock video card coolers connect to the vid card PCB, not the MB.
2. The motherboard does not have molex fan connectors, it has 3 pin, or 4 pin PWM connectors.
3. The one included antec tri-cool takes a molex connector, and has a switch for fan speed.
4. Most people with this case use two yate loon or two nexus fans, although two scythe fans would also work; these along with some sort of fan controller. If you don't really care about noise then the stock tri-cool is fine, along with another 120mm fan, which can plug into a molex, or the mb (your call). I use one yate loon and one nexus; the only reason for this is that I manged to buy these for a very cheap price ($6 total).
5. Mini ninja is the heatsink to get with this case.
6. The stock PS is absolutely fine, but some have experienced coil whine with it. The PSU in my 2400 buzzed under load, I found it very annoying, but I opened up the PSU and injected superglue into the torroids, which all but eliminated it. The PSUs in these cases are built by Seasonic, and parts which fit in this case will not overload them. The 8800gt draws less power than a gts. Read silentpcreview.com for real world power draw of typical systems. The 380su PS in my NSK2400 is running a heavily oc'd cpu and an oc'd 8800gts. I also swapped out the rear 80mm psu fan for a panaflo to reduce noise.
7. spcr.com has a good review of the nsk2400/fusion.
8. Random info: it's possible to fit an ATX board in this case with some modding.
Wow, thanks a lot for your response and your advices ! It clarified a lot of things :)
Some remarks :
I added now the scythe mini ninja to my shopping list - with another fan, according to spcr the included fan is a bit loud. I was planning to use a zalmann 8700, but you (and practal and spcr) convinced me
I was also planning to replace the tricool with 2 noctua ( or yate loon or nexus ).
I wanted to replace the PSU with a 500W seasonic model, maybe modular but replacing the antec PSU fan is attractive ( especially for the price ;) ).
i would go with the strider 600w or 750w and get the mini modular cable pack, that will make your wiring look great!
Some remarks :
Hold off on another fan for the mini ninja, with two 120mm fans there is a good chance you can use it fanless.
I'll think on that, thanks. Moreover there's a passive version of the 8800GT made by sparkle, if it fit in the Antec fusion - i see that the card is a bit large -, then it should be very silent.
Just keep in mind with the video card that anything that extends above the pci-e mounting bracket with interfere with the top and not allow it to close without modification. Just something to keep in mind if you are entertaining the idea of a passive card.
Do you think the new ATI HD3870 will fit inside this case ? I know it's a double slot card but I'm unsure how long it is ?
