Antec Earthwatts hissing
Avengeance
Anyone ever hear of this hiss? I am guessing something is going out on it unless its just the coils hissing. Should I replace it? I dont even know if its still under warranty. What do you all think?
It is actually pretty common on some older Antec models. It might be the coil, but unless it came that way new the units I have heard with this problem always had failing capacitors. You should probably look towards replacing it sooner or later.
I have a 380W Earthwatts that is about 2-3 years old now and I have had no such problem. How old is the thing?
I have an EA380 too and I don't have those problems. Which Earthwatts do you have?
I have the 500 I think. I will have to check. I just recently replaced my mobo, processor, vid card and ram. It was hissing worse before this but now it hisses less and ONLY in games. So its load dependent. I used to have a core 2 with a 8800GT but now I have a X4 945 and a 5870 vid card. Not sure which uses more power.
I'm pretty sure the system with 2x more cores and twice the GPU power uses more power.
