Antec EarthWatts 750W
I don't get why they run seperate 4-pin and 8pin cables... why don't they all just do 4+4...
But still looks good :tup:
Using both cables is common on dual CPU boards, so including both is fairly common on larger PSUs.
I'm thinking some people with case windows & boards that use a 4-pin probably don't like the 4+4 setup either. Having the other half just dangling there doesn't look as good as a 4-pin connector. The extra wire isn't that big of a deal, as you're just about always going to have to hide some spare wires if you're not using a modular PSU.
Plugging an 8-pin EPS12V into a 4-pin P4 12V connector is just fine. They were actually designed so that would work.
