My PSU ( Antec Earthwatts 750 ) has steadily begun to make a ticking noise, I think its the fan. At first is was intermittent, about once every two days for like 5 seconds. It's now 99% of the time it ticks really loud.
I checked that there's no obstruction to the fan, and it doesn't make noise when I manually spin it, so it makes me think its the fan motor or bearings at higher RPM than I can manually spin it.
Any one know if I can swap the fan for another case fan?
I'm a bit concerned about my replacement fan not having enough airflow or drawing a different amount of current. I want to put in an Antec TrueQuiet 120. Good for about 21.5 CFM ( I want to keep it on the lower rpm setting).
Also do PSU's have 3 pin connectors?
I don't want to damage the PSU because I really think its a nice unit. I'm also tight on $$ so a new PSU is not an option.
