I have recently purchased the Antec DF-85 and am looking at an ssd drive. I was informed that the drive bay is only sata 2 3gb. What makes a connection 3gb would it be just the cable or just the connection? If it is just the cable then would it be possible to replace the cable or is it the drive connection in the swap bay? My motherboard supports sata 3 6gb. So what do you guys think?
