Antec cyclone blower case fan
actually im pretty sure that it blows the hot air out the back of the case.
i have one but im not gonna hook it up just to find out :)
You're right it draws heat out. It probably would of workd better if it did the opposite. But it would of brought a lot of dust in as well. So you put this under your gpu. And have your gpu fan drawing air thru the heatsink. Then you have the blower sucking air away. Almost seems like the two would fight against eachother.
Yeah it probably does. It´s excellent if you smack a heatpipe or something on your video card though.
