Antec case opinions please
I have the same case in black that came with a 400 w PSU and Its great It has room for everything you can think of.
I have an old Antec case, an PP-282S, which has been a great case. It is well built, sturdy, is well finished (no sharp edges in it at all), and absolutely nothing on it or in it has worn out or broken.
I have modded it a bit, side window, cut out for extra fans, repainted it. All panels are easily removeable (and are removed often) and no matter how many times I take it apart the fit is like new and nothing is sloppy.
It is easy to work inside of and has a removeable drive cage for easy access.
I transport it to LAN parties at least twice a month, and in spite of alot of rough handling, it still looks almost like new.
Quality all the way!
The one you're looking at has been pretty popular in the past (it's been around for quite a while). As far as Antec quality, I would recommend them to anyone. If you like the case, it's features and price, I would definitely say you can't go wrong with an Antec..
I have the same case, but in the PlusView1000 variant (preinstalled window). I've had it for over a year and it is great. Good airflow, and plenty of room. Just don't look to use it as a LAN box ;)
