antec case front
ictrlu
Not really sure where to put thisquestion but...anywho...I have an Antec server case...1080 or something.It's the ones with door up top and the grill at the bottom.Anyway...I was wondering if there was an easy way to take the front of for cleaning purposes.Everytime I wanna clean it, it's such a b*tch to do becasue I cant get one of the latch things holding the front to come loose as its behind my optical drive bay.TIA.
To get the ones on that side, you have to take off the back side panel and get the top and the bottom, but the middle one is more fun - you have to remove your floppy drive cage (the upper one) and get your hand way back in there to push the last tab off
i have that case and i can get the front cover easily. the ones on the left hand side are easy to see and to get to so thats never a problem. for the right hand side just take off the back panel. for the ones on the right side i would suggest using some type of took to make it easier, i use a screwdriver.
Well, I ended up breaking off the right side middle latch because it was always a pain for me too - bezel still fits tight and clean -- so I recommmend it! Also remember you gotta slide your drives out if you're using the stock drive rails.
