Antec "Bigboy" 200mm replacement?
ballistic
Hello, the 200mm fan on top of my Antec 900 is no longer working and I filled out a RMA/Replacement form asking if Antec could replace it for me. ( I asked if I could get the 200mm Blue led fan from the 1200 if possible )
I know there are a couple sites that sell the 200mm tricool but has anybody found the 200mm tricool LED version from the 1200? As long as I have to replace it I might as well go for something with a little more bling.
Also in case antec won't help me with a replacement, hoping it's covered under warranty, does anybody know if there are any other brands of 200mm+ fans that will fit in that mounting spot?
Thanks for any responses!
Yeah, I was told that they are easy to deal with and I really hope they can somehow hook me up with the fan from the 1200. :D
Well I was asked to take a picture of the fan, fan blade and invoice so I sent that in and then was asked if I had a custom support number so I replied back with that and have heard nothing since so I am hoping they are thinking of replacing my fan. :)
This reminds me, I need to unplug my top fan, My cat all the sudden likes to sit on the grill
I broke my bigboy my very first day witht he case a while back. This was before they even offered it on their site. When they finalyl did it cost me more than any fan I had ever bought and it was a huge pain to install. I don't blame Antec, it was my fault the fan got busted, but I hope I never ever have to install one of those things again.
