Nightfall84
- Jul 19, 2004
Antec definetly makes great cases. Including the Aria. Excellent modding potential in a little box
No that would be a PS-2 style case.BillR said:No new Aria, but there is an addition to that line of cases.
tree_ said:I'm worried about cooling with my 3200+ and 9800Pro. What are some cooling mods I could add without drilling holes in the sides and such.. Anyway to just add a fan in there or what?
tree_ said:I don't need the card reader so how would I go about adding an 80mm in the front? And for that extra PCI slot did you use the PCI blower that comes with the Antec? What were your specs and temps with just the one fan?
MrE said:By putting an 80mm fan on the graphics side of the case, my overall temps dropped by 6c which proves the Aria (just like any other case) benifits from positive air flow. The side fan intakes and the 120mm on the back pulls out the heat. I used a SilenX fan so its almost noise free. It's worth buying a hole saw and spending the additional 30 minutes and installing the fan.
And, if its any consolation, the Aria stock (without mods) ran cooler than my Shuttle SN85G4 that it replaced on the CPU side by 4c. Course the SN85's suffered from dropped NIC connectivity if the box got too hot
Well, you also benefit from from positive air pressure just like any modern ATX case. My rig runs much cooler with the 80mm intake fan on the side panel without overclocking. So, the overall temps drop (CPU/GPU/Internal) which helps out with stability and of coarse peace of mind when you DO decide to fool around in overclocking.sleepeeg3 said:Problem is, without intake vents somewhere, your temps are not going to be good if you plan on overclocking. You really should not need to worry about it, if you don't.
I didn't run into this problem. I installed the cpu/heatsink+fan and ram on the motherboard before inserting it into the case. It slide right under the psu and mounted fine.tree_ said:Daridium I've head a lot of people complaining about having to take out the PSU to get the cPU and hs/f in to fit, Was that a problem you had to face or did it all fit into place just fine?
ALYNCH75 said:What CPU cooler are you using. To tell you the truth I think the Zalaman CNPS7000 AI CU is the the best cpu cooler. It works on all the CPU's the amd 64(754ping), the AMD athlon XP (462 pin socket a) and the Intel pentium 4 variations.
DimSum said:Maybe I'm blind or something but I didn't see any indication on any website that the Zalman CNPS7000 fits with the LGA 775 chip. I was thinking about going with the Thermaltake Silent 775. Anyone have any opinion on this?
Here's the link: http://www.thermaltake.com/coolers/cl-p0092silent775/cl-p0092silent775.htm
williamjohansson said:i have an aria case with a lga775 p4 3,0 ghz, and i use the Zalman CNPS7000b-cu cooler, you need to get a little bracket thats sold seperatly, only costs a couple of bucks.
DimSum said:Thanks for the info. It certainly saves me the trouble of ordering something that i'm not certain would fit. Any ideas if 80mm fans would fit if I have HDs hanging? I unfortunately don't have any spare fans lying around for me to measure with.
ALYNCH75 said:Look forget about whatever you are thinking. Look for the Zalaman site they have several versions similar to the CNSP7000 that will work with your cpu.
Bigshot said:One other thing you can do help out with the air flow is to remove the rear fan grill one or both of them. I still don't know why Antec did that?Doing so also seemed to help with the noise of the fan.
