****Antec accent lighting quick look****
stulid
Antec-Accentlights2_zpsf82d3ad9.jpg~original
Antec homepage - http://www.antec.com/product.php?id=706179&pid=105
Here is a quick look at Antecs accent lighting LED strips.
They are designed to add a soft glow in either red or blue via 6 leds on each strip, these are very simple to use and are powered by USB with an ON/OFF switch near the USB connector and a simple adhesive backing to stick wherever you want them to add some mood lighting to either around the back of your monitor, under your keyboard or underneath your case.
Product packaging.
IMG_3570_zps1d8ee16c.jpg~original
IMG_3584_zps64687239.jpg~original
Contents.
IMG_3587_zps7daa4c33.jpg~original
Closer look.
IMG_3591_zpsb726148a.jpg~original
ON/OFF switch, really nothing to say here.
IMG_3592_zps2a51aeb7.jpg~original
370mm long.
IMG_3594_zpse245907a.jpg~original
So you can cut them to length if they are too long for you.
How they look in the dark.
This is quite hard to photograph something in the dark so I will do my best.
IMG_3609_zpsa9d38453.jpg~original
IMG_3619_zps569ec8d5.jpg~original
IMG_3616_zpsb1eadf5a.jpg~original
IMG_36221_zpseea926af.jpg~original
They can be placed virtually anywhere to add a soft glow. But with two or more there's no reason why you can't get creative.
IMG_3624_zps1b85483e.jpg~original
IMG_3630_zps9b406251.jpg~original
Final words.
For £8.99 in the UK, these are a cheap and easy way to add a bit of mood lighting wherever you can stick them, if you have multiple colours then you can do some really creative ideas and still have the convenience of being able to turn them ON and OFF.
Approved_zps98d6f1af.png~original
this is not new...I've had an Antec LED strip on the back of my monitor for years now
