Antec 900.. what's next?
RADEoN
List:
1. Two holes, 2.5 inches bored in the bottom, fuel line cut along the back and put around the jagged metal to not short anything out.
2. Power/Reset/HDD LED's cut and spliced to add length.
3. Hard drives turned backwards (only worked with my PATA HD's :( )
4. Fan controllers all double sided taped to inconspicuous spots around the case.
Is there anything else I can do for ideal cable management before I put my powersupply in monday night when it arrives? I like advice and ideas :)
corsair 1,000 watt, and I'll get a better picture give me a few :p
HX1000 ftw
Pull excess cable in mobo side taught and get it out of sight. any wires that are exposed can be twisted/tied in a loop. Door edge molding may prove to be a little less conspicous than fuel line... but waht ever works.
