Hey guys. I've finally got all the parts for my new computer I'm building (first tiem building a computer). I set the mobo up with ram, cpu, and graphics, and it seemed to post (it came on, I was able to go into bios). So I went to start installing into the case.
I got the I/O thing set, figured out the brass standoffs, but then, I looked for screws for them.. and... there's only 4 that match the image in the book. There are other screws that will work for it, I looked, but I dont know what ones to use. I know some if not all that work for the brass standoffs seem to work in the PSU, which I seem to need 4.
It seems odd to me having 9 brass standoffs, but only 4 screws... I dont really know what I'm doing, and want to make sure that I dont need some of the other screws before I try using them.
(I dont know if this should be in mobo section, here, general build, or whatbut heh, some help would be greatly appreciated)
(cpu: Q6600, MoBo: evga nvidia 122-CK-NF68-A1 680i, RAM: corsair dominator 2x2 8500, gfx: nvidia 8600gt (quiet you <.< I'll upgrade soon), psu: corsair 650tx, hdd (for now) WD sata 640gb)
