Antec 900 Question
berndawg3
How loud is this case? How would it be when paired up with 800RPM scythe s-flex's? I'm not sure if I should go for this case or the P182...
The case isn't loud at all and i would definatly go for the 900 rather than the p182 its so much bigger as a mid tower case.
Loud? Only when the stock TriCool fans are set to HIGH. 800 RPM? I can't even hear my Tuniq, and its over 1000 RPM. The BigBoy 200mm on top can be set to HIGH, and is barely audible. Antec 900 is an awesome case.
i have the 120's on low and 200 on medium. it is just a soft hum in a silent room you can hear it but is no louder then a run of the mill generic case with only 1 fan.
I own this case ... it may not be loud when fans are slow ... but ... you hear everything as there is not 'noise insulation' what so ever ...I still like it since it is so well vented ... ;-)
This not a SILENT CASE! Did u hear me ? ;-)
not loud at all , i built my rig with one bag in December if i remember right all of the case fans default to the high speed but they all have a LOW/HIGH switch and if you turn it to slow it is very silent and still more than enough airflow.
I have 5 120mm Yate Loons all at 7v and have the 200mm fan on low. You can hear a low hum/air movement. It's logical though that this is not a silent case--- the front panel is comprised of ventilated grills. And there's also the huge opening for the 200mm fan.
But I just love the open air flow of the 900. My q6600 @ 3.0 and 1.265V can not get over 50C measured by coretemp running prime95
The antec 900 build i have in our family room, is always set to high fan speed with the stock tri cools. There not that loud unless you think 28 decibles is loud. I got used to it and don't even hear it anymore. typing this sentence created more noise than the fans.
