Antec 900 is old...
I've had the case for 3 years and its getting crappy. First of all the cable management sucks. When your forced to put the psu on the bottom the cables that come out of the psu face outside of the case instead of in. This makes it hard to hide them, if you can. Sure it has two slits for cable routing but they are pretty thin and their placement doesn't really hide anything, just bothers your gpu. The cooling system while amazing at first leaves much to be desired. the front two fans are cool until they start collecting dust. The side fan actually makes gpu temps worse and because of the small holes on the side door that seem like a good idea it actually disrupts the air flow going out of the case. It is better off closed.
So with that any suggestions on a new case? 80 bucks or less?
Must fit a full atx board.
Good cooling
LED not recommended but atleast blue.
CABLE MANAGEMENT!
Tooless?
I'd recommend the Fractal Design Define R3, it has Corsair style cable management and sound dampening material throughout the case...
http://www.pureoverclock.com/article1131.html
It costs around ~$100 here in Canada (should be cheaper in the states) so it's a decent case for the money.
Nice, where in Canada did you find this for sale?
EDIT: Found it at a place I am not allowed to reference lol
