Antec 900 Dust
Usama
I have had the Antec 900 for 2-3 months now and I clean it every 2-3 weeks on the inside and outside. But the only place I cant clean is the front where the 2 fans are, it is building up alot of dust now. :( How do I clean it?
comprressed air and a vacume cleaner or a wetvac that blows and a vacume cleaner is how i keep mine clean
i just blow through it with an air compressor from the inside.
I have the A900 as well. All I do is take my hard drive bay out and get in there with a q-tip, air compressor, and a mouth cover. This case builds so much dust- such a PITA.
you can usually get a cheap air compressor with a tank at your local home depot/lowes/harbor freight. I got mine with a 2.5gal tank at Home depot a few years back for $79.99. You can also use it to fill your tires, hook it up to an airbrush etc.
or just use a <$10 can of compressed gas. i take the HDD cages out and apart every six months or so to clean out all the little crevasses. it takes a couple hours, but it makes me feel better.
