ANTEC 900 causing BSODs, weirdest thing ever.
z3r0-
I got the case back in novemberish and started getting BSODs after a while on my AM2 rig. I concluded it was the memory and got new memory. No issues for almost 2 weeks then they started popping up again. I swapped my OCZ PSU for an enermax liberty and remounted everything in the case checking for oddities. Same thing. Even underclocked it was happening.
Fastforward to january I get conroe. Same BSOD issues. Other people said it was the x-fi causing it. I was running caseless for a while with no issues. Was using the x-fi still and the antec 900 HDD bays. Put my rig back in the antec yesterday and I got the precursor to the BSOD tonight.
I've changed EVERY SINGLE PART other than the case and these BSODs persist. What the hell is going on? I've once again checked to make sure nothing is shorting.
Details on BSOD: every 24-36 hours firefox will crash with the "send error report" BS and it will BSOD shortly after. If I leave after the BSOD it will BSOD more and more to the point where it will not load windows. If I shut off for 2-3 minutes after seeing firefox crash or after a BSOD I'm set for another 24-36 hours.
I have fans over everything that gets hot and temps are better than without a case.
Apart from a ground (short circuit), I don't see how a case can cause a BSOD. It's either somewhere else, you installed it poorly, or the motherboard backplane is defective/bent/warped.
I know it sucks, but try running the system out of the case for a few days and see if it does it... :eek:
Is your heatsink getting proper contact? maybe all your fans are all exaust or all intake which would make temperatures higher than usual.
Don't screw the bolts too tightly, or they will bend your moboo.
You'd better check the output voltage of your power suplly, make sure they are not out of +/-10% around the normal value.
Like I said in the original post I've changed everything but the case. It runs fine out of the case. I just put it back in here 2 hours ago. PSU is fine obviously. CPU is on water and temps are the same as always. Even at stock this happens.
Also, now that I'm in a case my mic makes a odd crackling sound of sorts whenever I push my talk button in ventrilo... Seems like something is messing with the x-fi?
Maybe the case is acting as a radio antenna.....
I've actually had a few different cases that would cause BSODs and lockups.... run the system out of the case or put the system in a different case and everything ran fine.
From the pics I looked at of that case... it doesn't look like anything should be able to cause a short anywhere.. unless you have a standoff where it isn't supposed to be.
Have you tried not hooking up the front panel I/O (sound/USB)???.
What about not hooking up the case fans and running it with the side off (just for testing purposes)? You can use a floor fan or something to make sure the system gets cooled good while you are testing it without the case fans.
Side isn't on at the moment as my watercooling is external anyway. Good idea with the fans, took front USB off and the x-fi is still messed up, waiting on BSOD.
Are you 100% certain the standoffs are all in the right place?
What he said, make sure you dont have an extra standoff causing a short (IF you really think its the case).
As someone else posted, try and run the PC without the case, see how it goes.
On another note...what does the BSOD say? is the cause different everytime? May be a bad/conflicting driver.
I dropped a set of keys into one of my cases. Took me two and a half weeks to figure out what was causin random crashes. I felt like a total noob after that one.
Loose standoff, rogue cables/circuit paths, many possibilties...
I'll grab a pic next time.
Do you guys read? I WAS RUNNING OUTSIDE THE CASE AND IT WAS FINE. I got a BSOD a day after putting it in the case, plus it's happened 3 other different installs into the case with different hardware. I don't get spyware 4 times. Plus I run spybot and adaware weekly.
Again, I don't see how I can mount mobos 4 times and get a grounding issue. Every standoff is used (8 of them) and they're screwed down tight.
Are the connections from the MB to the switches on the Case connected right (power, reset, usb, audio)?
Random question: Is there a lot of static electricity where you live? Might not be the problem, but hoping to get more information. I'd double check all your wires to make sure you have no metal prong on metal contact going on.
As the other users have said, what BSOD message are you getting? This might help you and us a lot.
No need for that kind of attitude. You don't pay everyone here to help you.:mad:
