For those with the Antec 900, have anyone tried having all the 120 fans be intakes and have the 200 bigboy fan the exhaust? Seeing as the 200 fan moves a lot of air I'm thinking it can handle moving all the warm air from the case.
My HSF, Scythe Katana Cu, is pointed upwards and since the rear exhaust fan just sits on the side of the HSF I was wondering if I can have it as an intake too because the 200mm fan can probably move all the warm air anyways.
Has anybody done this? I'll test it out on the weekend and see if it helps the temps.
System Specs:
C2D4300@3.2 (1.4v)
Scythe Katana Cu
Gigabyte 965P-DS3 Active cooling on NB
8800GTS
Antec cyclone exhaust blower directly below and sqeezed tight with the VidCard
2 Gig Ram
620W PSU
1 DVD, 1 HDD on the bottom of the case
Antec 900 with the front 2x120 fans on the mid and top, 1x120 side fan as intake, 1x120 and 200 fan as exhaust. Intake fans have filters on them
Current Spring temps with coretemp .95
CPU
Cool ambient temps
34 to 38C Idle
>60ish Load on TAT Load
>50ish Load on OCCT or Orthos Load
N/B
32-38C
Warm ambient temps
CPU
>43C on Idle
>65ish-75ish on TAT Load
>57ish on OCCT or Orthos Load
N/B
40-45C
System Specs:
C2D4300@3.2 (1.4v)
Scythe Katana Cu
8800GTS
2 Gig Ram
620W PSU
CPU
Cool ambient temps
34 to 38C Idle
N/B
32-38C
Warm ambient temps
CPU
>43C on Idle
N/B
40-45C
