I am currious what direction the fan on the antec 900 at the top of the case is supose to blow? Like, I set a piece of paper on top of it and it floats up, and doesnt get sucked down. What I did was buy a large thin piece of foam and I was going to use it to keep the dust out of my machine. I figured if I placed it on top of the fan it would be sucked into place because the air was being sucked from above and being shot into the case. Well this isnt happening, the foam will float on top of it for some reason
Could it be my fan is spinning backwards, and is there any way to reverse this?
