Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have it and it is great to work with. Roomier than the Sonata, and better front intake fan placement. Although you want to whole under the front bezel where it meets the chassis so dust won't get in. Airflow wise, the BQE is a warm case dispite having dual-120's. That is because the intake vents are so narrow and the sideways harddrive cage blocks a good deal of airflow from the rest of the case. Review of the BQE and Sonata at SPCR.
