antec 330w truepower PSU
ciggy50
is this PSU any good?
I'm thinkin of upgrading my powr situation , simply because my
+12v rails are shockingly low (11.19) and this antec 330w PSU
is readily available in my small neck of the woods.
I am currently runnin 2 PSU's wired together (a 250w ibm slaved to a generic 300w).
all my fans and drives run off the 250w , while the 300w powers the mobo and the vid card only .
any input would be appreciated
I'd say go for it, however, you could easily get a better PSU from Antec fairly cheap off of the egg. How many drives do you have in that thing anyway...
i am in canada , so newegg is out .
i run 2hd's (40 & 60 maxtor's ) nd one dvd burner and one cd burner.
and this antec is available today downtown.
If I were you I would wait... Have you seen how much power the new 6800 ultra takes?!?!? :D The next gen stuff is going to take a lot of power, and I would get at least a 430watt. That way you dont have to worry about upgrading in the future
If I were you I would wait... Have you seen how much power the new 6800 ultra takes?!?!? The next gen stuff is going to take a lot of power, and I would get at least a 430watt. That way you dont have to worry about upgrading in the future
Actually , my next system will be a while off (6 months or so)
and will probably be A64.
but in the meantime , i want to squeeze a bit more MHZ
out of this tbred.
ok , so i went down and bought that truepower 330w
hooked it up and my +12v rail now sits around 11.68v
better than 11.19 , but not what i was expecting.
oh well , i got 10 days to make up my mind if i'll keep it or not .
Software utilities and your motherboards BIOS are not accurate in any way. You could have a rock solid 12v line and it would be reporting it as 11.68v. If you really want to know how good of job its doing you'll have to buy an external device such as a multimeter.
eh, I don't know. My ASUS reads well as far as I know if my PSU is reading right. Right now my 12 volt is reading 11.916, thats on an antec 430 watt. But on that MSI, burning is probably 100% right, its the same way with temps.
Voltage and temp readings vary from board to board. None of them are very accurate and thats why PSU reviews that post results from readouts in the BIOS or a software application are bogus as far as how stable the voltages are.
