Antec 300 vs Coolermaster 590
yfel
I'm not really concerned with the appearance of the two cases... they are pretty similar anyway. I'm debating between the two but I can't figure out which one would have the best air flow for a possible oc'ing rig. I've never had a case with any kind of real ventilation (other than standard rear exhaust, front entry). What do you guys think?
Antec 300 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042&Tpk=Antec+Three+Hundred
Coolermaster 590 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119152
I recently put together my sig rig and LOVE the Antec 300. I'm not even currently using anything but the stock 2 exhaust fans and it runs plenty cool. I'm waiting on 2 Yate Loons to come but I haven't figured out what configuration I want to run them in. Probably just as two intakes.
There was a review posted somewhere that compared the 300 to the 900 and in every case even without the extra fans, the 300 was only 1C higher.
Yep, I recently built a budget rig for a buddy of mine recently and I used the 300. To be honest, I was quite impressed with the case! Its simple, cheap, well constructued, excellent cooling, looks good, and everything you would want in a common ATX case. I will buy again if need be.
I just bought the 300 - should be here today. :D looks like maximum airflow in that thing, plus it's got the top fan. there's room for more hard drives than the 590, too.
I don't get why so many of these cases have bays for so many 5.25 drives and only a couple for hard drives. I mean, who puts ***NINE*** CD or DVD drives in a computer?
I have the 300. Running cable in this thing is kind of hot/cold. The space between the right side and the hard drive rack is nice, but outside of that, there is not a lot of room in this case. With a full sized graphics card you will not be able to use all 6 hard drive spaces. My 4850 blocks at least one of the spots, possibly two. I like the 300 a lot, but I would seriously check out the 690. The 690 has as much airflow as you are going to find in an unmodded case with spots for 7 120's, 4 of which can also fit 140's. I've seen them both in Fry's and its still a toss-up between the 2 cases. I went with the 300 because it was less expensive at the time.
I found the cable management to be not too bad! The back compartment is definitely a nice feature. I've never had a bottom mounted PSU before so I didn't know what to expect with the cables, but all in all it was a lot better than I was afraid it might be.
I have to say though, the power and HD leds on this case really suck! They're just two little teeny cut out squares next to the power switch. when I say "teeny," I mean like a couple of millimeters square. they're both blue, too, so from a distance you can't even really get a distinct sense of HD activity.
Other than that minor gripe, I really like the case. very easy to work with, and great for the price - definitely worth the money. My temps are already 7C lower, and I don't even have any front fans yet, and the back ones aren't even running at full.
If I were building a desktop instead of a server I might have gone with the coolermaster. The drive bays looked like they might be better designed, with a separate drive cage (they should give you two, though), and maybe more sound dampening possibilities. I also like the way the top grills are flush instead of how it sticks up on the antec. My main case is a coolermaster, and they are nice cases. But for a server, I think this 300 rocks. I feel like I got a deal for $60 shipped!
I snapped a couple of random pic while it was in progress, nothing fantastic, just to give a very general idea of the case and how the cables route to the compartment:
antec 300
Thanks for the opinions. I'm going to go with the 300... the 690 looks nice but it's probably not much better for what I need, and the free shipping on the 300 is definitely a plus.
that price on the 690 tukson posted is pretty tempting! :D
btw, I just added a couple of shots of the LEDs -- when you figure my pinky barely fits on the reset switch (the piece with the dot in the middle), you can get an idea of how small/useless they are. I've got to figure out a way to mod these, they're really bad!
I can see why you'd go with the Antec for a server. Without a big graphics card to get in the way, the hard drive rack is just fine. Plenty of airflow in that thing.
