Carlitos714
- Nov 1, 2009
Whats up guys this is my first work log. This computer is already up and running there are still a few things I need to add like red led fans and uv lights.
I found out a few months back my step son (age 13) was going to come visit us from Brazil for a few months (we are hoping he stays). Anyhow I wanted to give him a welcome gift. I had a few extra computer parts so this is what I came up with.
I got ideas from other people throughout various forums.
Oh yeah I'm not the most artsy person so this was a learning experience for me.
Here is what the rig includes
**Core 2 Duo E7200 (lapped) @ 3.8 Ghz
**EVGA 780i FTW
**BFG LS-550 Watt Power Supply
**EVGA 260 Core 216 Superclocked
**2 x 2GB Mushkin 1066 Mhz DDR2 RAM
**LG DVD-RW
**320 GB Hard Drive
**Window 7 Ultimate (64 Bit)
**D-TEK FuZion V1 CPU water block
**Viper John North Bridge water block
**EVERCOOL VC-RF VGA Cooler on South Bridge
**Swiftech MCR-220
**Swiftech MCP350 w/ XSCP Resy
**2 Scythe "ULTRA KAZE" 3,000 rpm 4 radiator
**PrimoChill 1/2" Red UV Hose w/ 1/2" "BIG BOY" fittings all around
**Scythe"KAZE MASTER" 5.25" Bay Fan Controller
**2 antec tricools non led on front and 1 on exhause
**140mm antec fan on top exhaust
**23" Acer P235H HDMI
***have an extra 120 rad might add it in later
Right away I chopped it up and sanded that thing down.
sanded the side panels and did some more cutting. the mcr 220 is going to be red
Sprayed 2 coats of primer. sanded with 400 then 600 grit
Sprayed 3 coats of gloss black. sanded with 600 and 800 grit between sprays
Some parts are red
Sprayed two coats of clear coat. used 800 grit between sprays. the clear is tricky to use. I learned a lot on the do's and don'ts. Im not totally happy with the paint job but oh well.
Leak Test
Found a leak. It was a loose fitting.
Finally up and running. Still need to put a red 140mm fan grill, red led fans all around except top fan, uv lights to light up that uv red tubing. Maybe red leds on the resy too. I cut out the side fan mount. I think the kazes will bring good air flow and help keep temps down.
A Scythe"KAZE MASTER" 5.25" Bay Fan Controller is now on the empty 5.25 bay and the side panel is now installed.
The back side
The set up w/ a 23" acer and a new desk. He was amazed at this computer. He loves it. Especially after I explained what all the "tubes" were for!!!
I hope you guys like this log. I realized it takes a lot of time and patience to put together a computer like this. Thank you guys. comments and opinions are welcomed!!!!!
**EVGA 780i FTW
**LG DVD-RW
**320 GB Hard Drive
**Swiftech MCR-220
Some parts are red
Leak Test
The back side
