I was told to try as best as possible to keep a positive pressure in the case with the fans. As in more intake and less exhaust.
So I bought an antec 300 case, and it has two front fans, the top, side and a rear.
Two front are obviously intake, and the rear is exhaust.
What should the top be set too, and what should the side be set too? Is this 'positive pressure' thing a bunch of BS?
I was thinking the top should be an intake, and that way the side fan will be good for the CPU and heatsink as it is right in front of it and can get that heat sinks hot air out of there quickly.
