I am hoping someone can help with this issue I have with my Antec 300 case causing my 460GTX to continually run hot. I am measuring Temps from GPU-Z for my GPU and AMD OverDrive for my CPU.
Here's some quick environmental things: Generally the room the computer runs in, is on average about 21-23C on any given day, up to 30C on very hot days which are fairly rare. The case doesn't have the best airflow around it, but has several inches of clearance on either side and about 10 inches in the back, the front is completely unobstructed.
My 460GTX while idle runs about 39-41C and under any moderate load e.g. Diablo 3 on low @ 1600x900 causes the GPU to heat up to about 65-70C, with other games such as Assassins creed, it gets up to about 80C, and causes the fan to spin up. Most games I have to run at minimum settings and usually under 1400x900 just to keep the GPU card under 70C.
Any ideas why the GPU is running so hot? It's placed at the top PCIe slot, which is close to the CPU and furthest away from the bottom mounted PSU.
The computer:
Antec 300 w/ 4 case fans. 1 intake and 3 blowing out the hot air.
I have an Antec NEO Eco 520 which unfortunately is on the bottom of the case and exhausts hot air up towards the GTX460.
AMD Phenom II 1050T w/ Corsair H50 (runs pretty cool between 23C idle and 34C Max)
8 GB DDR3 ram
single HDD
460GTX
poor cable management as well.
The computer:
8 GB DDR3 ram
single HDD
460GTX
