Antec 1380 is the smallest SFF?
exe
Are there any smaller aside from Shuttle? I read some complaining about the heat generated in the small box; but I am looking for the smallest, and also just to put 2 mid/low end graphic card, 1 HD, 1DVD drive. Thanks for the info.
It is the smallest other than shuttle but how do you plan on getting 2 GPUs in there?
It's not too bad with heat if you go low end.
2 GPU? One will be in the x16 slot, the other an x1 slot. I need to run multiple monitors, low end is fine as I do not game.
