ANOTHER Wireless LAN Problem
blut3ng3l
I have the WMP54GS router and a PCI Wireless Card. The router on my wired PC works good. On my other computer, the one using the PCI card, doesn't work now. I had to do recovery and it made me install the drivers again. Before I had to do this, when I installed it the first time, it worked fine when I did a bridge connection or something.(I think that's sharing through XP networking) I think it also worked because there was a pervious High Speed connection on it through an ISP at another house. Now it all seems to be back at default. Now I can't figure out how to get it to work when I install it again. The status is working. When I click "Wireless Network Connection" icon in the tool bar, and then click "linksys" under available wireless networks, and click "allow it to connect to the selected wireless network, even though its not secure", and click the "connect" button, it still doesn't work. If I do peer to peer it get's a working signal, the ineternet doesn't work though.
First off, make sure that you look in your device manager and look for any type of yellow "!" marks or anything of that sort, so you can be sure the software installed properly. Second try not to fiddle too much with the home networking wizard. You should be able to get things running by checking your tcp/ip settings and making sure they are right, as well as running the setup on the router from your computer. (try running the setup on the router by logging into it would be a good second step i think.) Would check to make sure that in the tcp/ip properties for your card that they are according to your router/wireless card documentation, be sure of your dhcp settings especially, that it is set to default. Else try looking up the website for either manufacturer for added help in their support sections
You want infrastructure on the card if your associating to an AP (your wireless router) You also want to disconnect any windows network bridge. No need for it.
Agreed on that. The windows bridge is useless. The bridge just makes it so your computer can connect to two different networks, (hence bridging them) and acts as a router from either network to the other one, and vice versa.
Actually no, it acts as a bridge. The network segment will be the same on both interfaces. Ie, 192.168.1.X on one and 192.168.1.X on the other. ICS is a basic NAT router. A windows bridge is well, a bridge.
Damn. And here i was thinking i had remembered what a bridge does. I allmost had it too... Just that it keeps the same ip on both interfaces... and dosn't do any NAT
