Another "Which case should i get" thread
defiant
Okay guys, ive narrowed it down to either of these thermal take cases
the blue wingo
http://www.thermaltake.com/xaserCase/WinGo/v7000d.htm
or the aluminium tsunami
http://www.thermaltake.com/xaserCase/tsunami/swa/swa.htm
im honestly stuck on which one to get, the tsunami looks pretty snazzy but has 2 less fans than the wingo...or would the fact that its aluminium provide better cooling potential given that the wingo is steel? The tsunami also comes with a 400w silent psu but because I want to get a 6800 ultra I was thinking about going with a 480w psu, in which case it would probably be better for me to get the wingo seeing as its cheaper and comes without a psu. :confused:
opinions very much appreciated :)
Go with the tsumani, the WinGo is just too tacky looking. Also, it will be a lot quieter since it uses 120mm low rpm fans that push the same or more cfm as the multiple 80mm fans in the WinGo. You can also cut yourself a blow hole in the top panel to further increase the cooling of this case.
well I was thinking about the Tsunami, but the problem is that there seem to be no reviews of it at all, so I was wondering if the case is new, or is it any good or what?
In case you didn't notice, it bears a striking resemblance to the CoolerMaster WaveMaster case. My guess is they are both made by the same company and would have similar cooling characteristics.
i found this review by going to the TT site
