So, the upgrade probably won't be happening for a couple months, but I felt like posting to feel out which way I should go. Here's my current system:
DFI Lanparty NF4 Ultra-D
Venice 3200+ O/C to 2.45 gHz
1 Seagate 7200rpm 200gb Sata HD
1 Seagate 7200rpm 250gb Sata HD
ATI x800xl 256mb
1 gig Crucial Value(1 stick)
SB Audigy 2 zs
So, I probably will only be upgrading 1 thing, maybeeee 2 if I can find the money(and then part with it). So, if possible, give 1 choice for "upgrading only 1 thing" and 1 choice for "upgrading 2 things." Also, if you can, give me a guess for how much I could sell my old part for(like if I upgrade video, how much will the x800xl go for).
Anyway, here are the choices:
1. I have a ton of movie files and stuff on my computer, and my hard drives are getting full. Therefore, choice 1 is get a 74gb raptor and make it the boot drive(the 200gb currently is) and use the other 2 as storage.
2. I like to play games, and turning down the effects on Oblivion makes me sad. Also, seeing my x800xl get up to 81 Celsius(with atitool alreading boosting the fan) makes me sad. Upgrade to a 7900gt and sell the x800xl.
3. Get another gig of ram and run in dual channel!
4. Get a dual core cpu(I don't do much encoding) and sell the 3200 Venice.
So, please, offer your advice. I'm not sure if I'll be able to upgrade 1 component or 2, so if you can provide choices for both scenarios and how much I could probably get for selling the current hardware I plan on replacing. Thanks for all your help guys.
ATI x800xl 256mb
SB Audigy 2 zs
