I've been away from the computer scene way too long and considering how fast hardwares are being updated, I'm needing some suggestions. Hopefully I can keep my budget under a grand.
Anyways I decided I need to upgrade my current computer that's listed in my sig since it can't even run Q4 at constant FPS, not even in WoW in that case.
Basically I want to keep what I can from current computer which I believe is only the case, DVD-RW, harddrives, and my soundcard(I think the onboard on the mobo I'm about to buy is better then the actual soundcard.)
I did a little research on my own and this is what I came up with:
mobo : http://www.newegg.com/Product/Product.asp?item=N82E16813131013
videox2 for SLI : http://www.newegg.com/Product/Product.asp?item=N82E16814143049
PSU : http://www.newegg.com/Product/Product.asp?item=N82E16817163109
RAM : http://www.newegg.com/Product/Product.asp?item=N82E16820145034
CPU : http://www.newegg.com/Product/Product.asp?item=N82E16819103747
I think I went too overkill on some parts and a little weak on some parts. I'm hoping someone can give me suggestions on other parts to even it out.
