Alright guys I know you do way too many of these but hopefully this one is short and sweet and interesting. Questions answered below but a brief synopsis of what I am doing is that I am working on my Christmas present to me . Building a custom case that will "hopefully" disguise having an HTPC in our living room. It will be done almost completely out of hardwoods(Walnut and Maple) so heat is definitely a big concern. Low power, low heat, and suggestions on good quality, low noise fans.
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs). Will be used as an HTPC for movies, streaming, and light gaming/LAN gaming (Think League of Legends, Age3, maybe SupCom2 etc...)
2. Will you be overclocking? No
3. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection? I am trying to do this pretty cheap and for the rest of the parts needed hoping to get away with less than $300. This is just for the above parts all costs for building the case are different from this
4. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)? No not really. Nearest Fry's is almost 4 hours away so no savings would be worth the drive
5. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need. I need a modular PSU, GPU, SSD and recommended low power, noise fans
Edit: On the SSD I am fairly certain I will go either a Samsung 830 128gb or a Intel 330. Just basically going to snag the next one that comes on sale so most of questions are on the PSU, GPU and any recommended fans.
6. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions. I already have
CPU - G620 Link
Mobo - ECS H61H2 Link
Ram -Samsung DDR3 4GB Link
7. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list. Skip since I have. Down the road I will get a USB3.0 card
8. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output? Will be mainly using the 55" 1080P Samsung LCD/LED but for LAN it will be on 1600x1200 or 1920x1200
9. Does this system need to fit into a particular space? Think entertainment center shelves, closet space, rackmount, etc. The smaller the better I suppose. I am making a custom case for this build so I have fudge room but still smaller is better.
10. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)? Well as stated above I am making a custom case. I have access to welding equipment both steel and aluminum, dremel, bending tools, plasma cuter, etc...
11. How important is the noise/silence of this system? As quiet and cool(less power) that is possible.
12. How mobile does this system need to be? I will work this out with case. Hopefully will be able to post up pics in a couple months. . . If it doesn't end up sucking ass
13. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Will be using legit copy of Win8 Pro
14. When do you plan on building/buying the PC? Well already have some parts ordered. I would like to have the rest ordered in the next month or so.
CPU - G620 Link
