Another recomend a case.
OhMyGod
Now that I am buying an external water box... I want the following in a case;
Mid-size
A motherboard tray that allows me access to the back of the CPU (this is a MUST) *this kills most*
Enough room behind the motherboard to do cable management.
The 2.5 inch hard drive bays mounted sideways (tool-less is a plus)
Any fans should be of 120mm size
Prefer bottom Power Supply (no PS need be included)
Front top or top front USB/audio/Firewire ports
Quality overall build.
Please make any recommendations
ThermalTake Element S is close.
It has the cpu cut out, bottom PSU (removable tray for PSU I think), USB on top front, some cable management conduit I believe and the fans are 120mm, 140mm, and 230mm. The harddrive cage isn't exactly how you want, but they are removed from the side with a system similar to tool less hot swappable drives.
Also the interior is all black. :)
