Another Rampage Extreme III issue
HORNO
Here's the next problem I'm having on my new build. I posted this on Asus support forum as well. You guys gave me better answers to my last problem so here it is:
I finally got around to installing Win 7 64-bit on my brand new (first) build. I have the Rampage Extreme III and I have the OS installed on a Cruial 128GB SSD which is supposedly SATA 6 ready. I have the SSD drive connected to the Sata 6GB connector. I have selected AHCI in the storage systems in the the BIOS before I installed the OS.
My problem is... everytime the drive accesses anything, I hear very loud accessing noises coming from what it sounds like, the SATA 6 connector on the motherboard. Now... I'm having trouble pinpointing exactly where the sound is coming from -- maybe it's the Corsair AX1200 PSU? I have read about people having coil whine issues with that PSU. I almost want to say that this is where the sound is coming from.
It actually sounds very similiar to the sound of a 56k modem when it was dialing up, crossed with a mechanical harddrive when it's accessing data. If I use the scroll on my mouse... I hear it access with each mouse scroll. As soon as the Windows 7 logo appears at boot... I hear it accessing. It makes scratching weird noises when accessing. I tried both SATA 6 ports and even the SATA 3 ports. The sound does it on those as well.
Has anyone ever heard of this issue and if so... do you know of any remedies? I am running the latest BIOS revision 1005. thanks in advance for any help!
Listen closer. Find out exactly were the sound is coming from.
You're listing parts that are not motherboard related.
Thank you, WorldExclusive. It got too late last night so tonight I will be listening closer. I need to pull the power supply out of the case. Sometimes it fully sounded like the PSU and other times I sworn it was the motherboard. There is the little yellow LED next to the SATA 6GB connector and every time that lights up and accesses, the noises start and they are in sync with that LED. I will try to post a video tonight if I haven't identified what the problem is.
A little off subject... but how much RAM do you have installed? If you have more than 6GB, are you seeing all 6GB in Windows? If you are, what type of memory are you using?
ivoidwarranties:
I'm running 12GB of RAM - all 12GB are showing up. It is Mushkin Redline:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226121
Now... since I'm a newbie, this being my first build... it looks like the RAM may be running at 1066 when it should be at 1600. I'm not 100% sure this is the case... trying to figure out where to look to see if it is 1066 or 1600. I don't know if that would cause a chirping noise like I have. I have to figure out how to get the RAM up to 1600... something I don't exactly know how to do. Obviously it's in the BIOS but I just need to figure that part out.
I have been doing a lot of reading up on the Corsair AX1200... a bunch of units were shipped with weird noises and now Corsair is offering RMA's for any noise issues. This may be the problem but I don't know until I separate the PSU from the other components... it's just too hard to tell if its the PSU or not. I have really excellent hearing and I just can't tell.
It should be under the "Extreme Tweaker" section --> "DRAM Timing Control"
Wow thank you very much for the pic! That will be very helpful.
Also... here is a link on youtube to someone who is a {Hard] OCPer...
http://www.youtube.com/watch?v=dj1T7JpORA0&feature=related
He has the Corsair AX1200 and this is sounding like the exact chirping sound that I am having. I can't wait to get home tonight and separate the PSU from the case. I think this is the problem though. After 9 seconds into the video is more of what it sounds like for me. Sounds sort of like a 56k modem dialing up to me.
Why would you even get a 1200W PSU? RMA it, sell the replacement and get something smaller. Judging by your system specs you don't need a 1200W PSU.
That's the PSU for sure. Those units are hit and miss so RMA it. Hopefully they will send you a new PSU that has been revised instead of repaired.
Corsair can't be happy with Flextronics.
AdvanSuper:
The build isn't over. I'm planning on getting another GTX 480 in a month or so.
WorldExclusive:
Yeah, I'm actually hoping its just the PSU and not the motherboard. Well see tonight! Hurry up day!!!
Update:
Yep... looking like its the Corsair AX1200 that's making the noise. I went onto Corsairs forums and they tell you to disable some of the CPU's power savings features:
C1E and EIST (Enhanced Intel Speedstep Technology)
I disabled those 2 and the sound sort of went away. I mean sort of because it still makes a weird noise when I start Furmark or other graphics stress tests.
Apparently... it will need to be RMA. But at I'm happy it's not the motherboard. That would be a pain!
Thanks again for your guys advice and moral support! I needed it!
