Another p180 thread?
dholster
So i have a p180b with the upgrades in it :)
my first question is, will the tuniq tower fit in the case with the motherboard tray now being raised up for cable management? if not, whats a good $50+/- cooler to stick on my e6600?
2nd question is the 3 adjustable fans that it comes with use 4pin molex connecters, should i leave those fans, with their adjustment controls on the case, or should i replace them with 3pin case fans and use a front side fan controller? i really like the idea of a front side fan controller if i can find one that works good, but most newegg reviews of almost all are negative, even the scythe controller, any suggestions here?
p.s. hiper 580w crazy long modular connecters fit just fine in there with the lower fan installed.
I'd like to know myself as well.. My original plan was to get dual front fans and keep the three tri cools (so having 5 fans total) but looks like having the dual fans won't be possible without some drill work. I emailed antec about this and they said it wouldn't be possible as well. Damn. As for the tuniq: http://hardforum.com/showthread.php?t=1161049&highlight=scythe+p180
May not be the same board, but just for reference.
You can make the 4 pin molex on the fans a 3 pin. Just get creative.
I had a fan controller that had 4 pin molex adaptors on it. I'll find it later.. well, I sold it, but it was neato.. did what it was supposed to do.
PIX!
